Ok so we'll get the technical part out of the way:
Now the issue:
As the title tells you, my network adapter seems to, well, suck. I just bought this laptop in June and I love it, except for the wireless capabilities. At first I thought it was just because of the distance from my router at home.
I am staying at a lodge in Northern Ontario and I have a Wireless N router hooked up to satellite internet. I am 50+ yards from the router in a completely different building, so intermittent reception is obviously expected.
However, it is frustrating when my friend who has an ACER laptop which is slightly bigger and more expensive than mine, doesn't have the same issue. I have 2-3 bars of reception according to my laptop, yet it drops frequently sometimes and moving the laptop the slightest amount (sometimes less than an inch) can make or break the connection.
I just accepted it for a while, but I was at work sitting outside in my truck and I had 4 out of 5 bars, and still the connection would drop out of no where, and be difficult to get back, even though the signal strength was good.
Then just recently I was at a friends place, sitting less than 5 feet from his router, full strength signal (5 bars) and the connection still dropped once or twice.
I've googled the network adapter and have found that many have had similar issues with it dropping signal and am wondering if there's anything I can do about it? It's really irritating to see it telling me I have good reception yet can't connect to the network.
- Windows 7 (32 bit)
- AMD Athlon Dual Core Processor 2.1GHz
- Atheros AR9285 Wireless Network Adapter
- Toshiba Satellite Laptop
Now the issue:
