281 - 293 of 293 Posts
I had forgotten that the cable was damages by heavy equipment. It's not necessary for low voltage cables like satellite but I believe the rules for electrical cables specify a minimum 18" depth with 3' under driveways. Roads may be deeper or at least require extra protection such as metal conduit or concrete encasement to protect from damage.
Bell and Rogers barely bury their cables at all but they are constantly being damaged and pulled up by people putting in new driveways or digging in their gardens. I've exposed the Bell cable several times here. One time I found a section it just laying on top of the ground in the front yard. The Rogers cable has been cut twice by other people and the new one is barely 3" below the surface at the edge of the driveway.
Discussion Starter #282
Of course the plan evolved...
Hi ExDilbert,
As per this earlier post (https://www.digitalhome.ca/forum/11-shaw-direct-satellite/125300-tough-installation-location-help-please-5.html#post1148421) the plan was ...we'll run the cables inside a conduit beside the road about 18 inches deep back to the Cabin.
Of course the plan evolved...as per this post (https://www.digitalhome.ca/forum/11-shaw-direct-satellite/125300-tough-installation-location-help-please-8.html#post1173676)...We were going for a 4 inch wide a foot deep but it wandered up to about 6 inches and down to 1.5 feet. (It took about 6 Hours with all the rocks and hand digging!)
We've had no cable issues for the first 7 years, but the construction 2 doors down, and the changes they made to the road grade during the last couple years (About a foot lower so the cable was only about 6 inches down across their driveway), along with the movement of heavy equipment over and over the conduit & cables, is what lead to the first, and now the second failure.
I'm actually surprised when I look back at how long it's lasted, & how well it performed all these years before the break. (It did take a little effort to boost the signal to the neighbor once the XKu LNB was installed.) Half of the original Cable was provided by my brother in law (the cheapest outdoor rated cable), and later the rest by the neighbor which had Gel between layers to prevent moisture ingress. Both were no where near the Quad Shield RG6 Steel core minimum Satellite specification I had asked for (and they said they'd provide).
At one time I was thinking Quad Shield RG6 Solid Copper Coaxial Cable but it was about triple the price per foot as I remember. At the end of the day, both Quad and Dual Shield have the same DC Resistance per Conductor @ 20°C @ 28 Ω/1000 ft Nominal. I assume Quad Shield RG6 Solid Copper Coaxial Cable will be less but I can't seem to find that info tonight. In hindsight, if it is substantially less lossy we should have bit the bullet and just paid for it.
I expect we'll be pulling all new cables next spring so I'll be sure to get it sorted long before then.
Solid copper may be better for DC resistance. That could help with powering the LNB but they seem to be fairly tolerant of lower voltages. At RF frequencies there shouldn't be too much difference.
Rocks and stones are an issue with buried cables, especially with direct burial or soft plastic pipe. Putting sand around the the cable or plastic pipe is recommended in rocky soil.
Discussion Starter #284
Hi ExDilbert & All,
Just a quick note for reference. I found the applicable ANSI Specifications for interior applications, and surprise it's quite recent (2018) which is a bonus. I suspect the exterior version of this spec, which I couldn't find, is not much different except for the outer jacket performance under environmental stress testing.
ANSI/SCTE 244 2018
Specification for Braided 75 Ω, Micro-Series Quad Shield Coaxial Cable for Connectivity and Dense CCAP/Edge QAM Applications
10.2.4. =>When tested in accordance with ANSI/SCTE 44, at 68°F (20°C), the maximum DC loop resistance shall be 103 ohms per 1000 ft (338 Ohms per km) for cable with solid copper
inner conductor.
For cables utilizing silver-plated, copper-clad steel inner conductor, the maximum DC loop resistance shall be 201 ohms per 1000 ft (659 Ohms per km).
For this application that means the voltage drop from the multiswitch to the Dish is almost double using copper-clad steel inner conductor, versus a cable with a solid copper inner conductor. Using 355 feet from the Cabin to the Dish (and 277 feet to the Neighbors from the dish) I suspect this could have some impact on switching at the LNB (or multiswitch in case of the neighbor). But without knowing the typical current, and reliable voltage switching limits at the LNB I really can't go much farther.
Using basic math 355 feet X 0.201 Ω/Foot =71.355 Ω DC resistance in a single cable. (55.677 Ω DC resistance for the cable runs to the neighbor's)
The "old" Phillips SDW5058 multiswitch power supply was 24 VDC at 750 mA Max. I've got no idea how much of the supplied current is sent down the line, but I know it's not much. If known then the Vdrop = IxR would be a simple calculation. Maybe a Shaw Direct (or other) Tech could chime in with the right procedure to figure this out.
I do know when we had continuous no broken cables from the LNB to the Cabin, even the cheapest RG6 Cable used worked fine for 7 years. So perhaps I'm just wasting my time going down this road.
Discussion Starter #285
Now I'm stuck...
Hi Folks,
I keep coming back to this unit as a possible solution if the Cabling is marginal. It appears to be a unit used in multi-residence applications in High Rises or Apartments (Condos)
The 300 foot solution look intriguing...
I'd love to get a simple explanation as to how to do this type of install (maybe a handbook or on-line course). Just for educational purposes though. I'm not looking for a new career :laugh.
I found the following while checking out the SD PI-6S module. It's about DIRECTV® but I'm thinking the same standards / information would pertain to Shaw Direct. My comments in Blue
DIRECTV® recommends that the distance between receiver and dish be less than 150 feet of solid copper RG-6. Here is why.
The 18 volts originating at the SWM16 must arrive at the SL5 above 16 volts for the SL5 (the DIRECTV® LNB) to operate correctly. Up to (2) volts can be lost in the coax. (Jim's edit => this means the minimum switching voltage is 16 or 11 VDC depending on what polarity is being sought on our Shaw Direct Systems.)
Model SL5 LNBs employ current management to minimize the current carried per coax. (400 mA total) Rev3 SL5 LNBs splits the 400 mA current equally at 100 mA per coax.
Current x Resistance = Voltage loss
Solid copper RG-6 has a typical loop resistance of 4 ohms per 100 feet. At 200 feet the resistance is 8 ohms. 0.1 Amp x 8 ohms = 0.8 volts loss
18 V - 0.8 V = 17.2 volts to the SL5
Model SDPI6S-T starts with 19 Volts to provided extended dish to Main Point of Entry distances. The extra voltage provides an additional 150 feet RG-6 distance. Model LA146R off sets the signal loss of 150 feet of RG-6. The LA146R located at the polarity locker does not affect the current loss in the cable to the dish. What is the voltage loss in the 19V/22k coax? Assume 100 mA per coax.
At 300 feet the resistance is 12 ohms. 0.1 Amp x 12 ohms = 1.2 volts loss 19 V - 1.2 V = 17.8 volts to the SL5
This is quite different than the Spec in my post above ~20% less resistance => ANSI/SCTE 44, "at 68°F (20°C), the maximum DC loop resistance shall be 103 ohms per 1000 ft" Or about 10 ohms per 100 ft.
Assuming the former 4 ohms per 100 ft., for the Shaw Direct system at the cabin, the lines have a resistance of 3.55 X 4 = 14.2 Ω
14.2 Ω x 0.1 Amp =1.42 volts loss 18 V - 1.42 V = 16.58 volts to the Xku LNB if solid copper core RG6 were used. This should be fine as it's above the 16 volt minimum spec for switching.
Assuming the latter 10.3 ohms per 100 ft for the Shaw Direct system at the cabin, the lines have a resistance of 3.55 X 10.3 = 36.565 Ω
36.565 Ω x 0.1 Amp =3.6565 volts loss 18 V - 3.6565 V = 14.3435 volts to the Xku LNB if solid copper core RG6 were used. This should not work (or not work well) as it's significantly below the 16 volt minimum spec for switching.
If we calculate using copper-clad steel inner conductor, according to maximum spec, the maximum DC loop resistance shall be 201 ohms per 1000 ft. So the math becomes even crazier.
So obviously some thing is wrong with my data and/or methodology. We know Dual Shield RG6 copper-clad steel inner conductor works for the 355 foot run to the dish.
I've assumed the old Quad LNB had more output than the Xku, as when the Xku was installed, the run to the neighbor's needed a boost (in line amplifiers) to overcome the 277 feet to his place. The loss for those 277 feet should be less than that the 355 to the dish, so it shouldn't need the boost - but it does. My explanation was the multiswitches pushed more voltage to overcome insertion losses to the LNB Feeds (like the Model SDPI6S-T above which starts with 19 Volts) and that benefit overcame some of the line loss as "The extra voltage provides an additional 150 feet RG-6 distance." If that's the case then:
the lines have a resistance of 2.05 X 10.3 = 21.115 Ω
21.115 Ω x 0.1 Amp =2.1115 volts loss 18 V - 2.1115 V = 15.8885 volts to the Xku LNB if solid copper core RG6 were used. Even with the multiswitch boost this would allow for marginal switching.
RG6 copper-clad steel inner conductor, if calculated in this manner, gives even worse numbers as it's more lossy than solid copper.
Now I'm stuck...
This might help Shaw Direct Blog
Shaw Direct uses two polarities for our service – horizontal and vertical, which both require a different electric voltage to activate (10.5 to 14.2 volts for vertical, and 15.2 to 21.0 volts for horizontal).
As long as the voltage at the LNB does not drop below 15.2v on the 21.0v transponders everything should be OK. The other issue is how the LNB draws its power. If it's shared between all 4 feeds than the total resistance will be 1/4 of each leg. If it's drawn on only one port (typical of some switches which use port one) then copper RG6 would only be required on that cable. I suspect that 10.5v may be the minimum voltage for the LNB to operate properly.
Couldn't find any current specs for the Shaw LNB but it may be possible to construct a special cable and measure it with a meter. Contacting Shaw or the the LNB maker is another possibility.
Discussion Starter #288
Still Lost...
Thanks for at least finding the limits M8 and the Link to the Blog (although I think you got the only Tech info there). => 10.5 to 14.2 volts for vertical, and 15.2 to 21.0 volts for horizontal => at least we know where the goal posts are. Now we just need to figure out how to get there every time.
As far as "how the LNB draws its power. If it's shared between all 4 feeds than the total resistance will be 1/4 of each leg." Without a circuit to analyse we are just guessing. I'm an Electrician with a couple years of Electrical Technician/Technologist Training ages ago at BCIT on top of that, and without data, it's impossible for me to figure this out.
Hopefully someone we read this and offer up some suggestions or answers on how Shaw Direct calculates Vdrop on the cables.:wink
It should be possible to measure the voltages at the LNB with the current cables. You just need to fabricate a cable to connect a meter. Then calculate the voltage drop and current draw.
Discussion Starter #290
Cannibalize a Cable Splitter...
Yes, I could make such a device. I'd just cannibalize a Cable Splitter like this:
But again, we'd just be checking the voltage level as we know it works now.
Discussion Starter #291
Hi again Gents.
My brother & I went up to open up the Cabin for summer last Saturday. I hadn't been there since last August and he winterized it in late September. The neighbor who we share the dish with keeps an eye on it for us, as he lives there year round. We were greeted with a stuck water pump, and mouse droppings in the pump room and garage. Oh joy!
The neighbor had told me he'd caught 9 mice in the pump room over the winter, and my brother in law who lives year round on the other side, said his cat had a great time catching mice as they exited near where the garage door meets the concrete and the siding trim this spring. There was a small Quarter sized gap there and they were exiting through it. We never had any mice issues before in the 50+ years that the family has had a Cabin on the property. I figured they were attracted by the heat in the pump room as there was no food in the Cabin. So we plugged any entry points we found, after we spent 2.5 hours to get the water system going...
Anyway, that wasn't the reason for this post. Since the last repair the Sat system ran flawlessly according to the neighbor. Last summer the Sony STRDN-860 AVR stopped functioning, so last fall I bought a Sony STRDN-1060 AVR to replace it. One of my passions is for decent sound systems, which my brother shares as well. Before the 860 failed the Dolby 5.1 output from the 630 Sat box worked fine (when a 5.1 signal was broadcast). But when we hooked up the 1060 we struggled to get it to work. We finally got it going by changing the Video & Audio Settings - HDMI Audio = Passthrough on the 630. But then there is no TV Audio, which is bizarre.
As most of the family are not into surround sound audio like my brother and I, we made certain to buy receivers (like the 1060) that will passthrough the last HDMI signal it was processing when the receiver is turned off (it's really just "standby"). This lets our wives (mostly) watch Sat TV without having to fiddle with the AVR.
So the question is, is there a workaround where setting it to something else will actually passthrough the signal as setting it to passthrough certainly doesn't work.
By the way, was this a "new" enhancement that occurred recently on the 630s ?
Thanks for your input as always.
Discussion Starter #292
Hi again,
I'm at the Cabin again and it appears the last splice failed. About 25% of the channels don't seem to be coming in for us, or as I just found out , the neighbor. While I somehow thought the Shaw Tech (Contractor) did the splices, the neighbor advised he did them in a hurry as the tech left and it started raining. He used the crappiest twist on connectors he had. So with all the rain this spring, I expect water ingress has shorted out one line.
As we are only here to put the boat in the water, I'm thinking I'll shuffle the cables to lose the least amount of impactful channels as above. I'm on an iPad so it's tough sorting out which one to drop after all the SD channels changes in the last year. So I'll try to wing it.
By the way, I happened to buy 700 feet of Quad Sheild RG6 in a box last weekend. I guess my "spidy" sense was going off and I didn't even know it!
Discussion Starter #293
Hi Gents,
Just a quick update. The Shaw Tech cut 2 of the AquaTight connectors off the feeds into the multiswitch and left virtually no slack. I had to back off the screws holding the multiswitch to the house to move things around. So after shuffling things about the bottom line is 2 of the cables have failed. After talking to the neighbor, and his wife, I ended up with connecting the remaining two good cables to get all of F2, as that's where most of their critical channels are found. Hopefully that will hold until I get back there in August.
