1 - 11 of 11 Posts
hey all!!
So, for a while now, when I turn on my TOSHIBA 46RF350U, there is a discolored line (or lines together) running down the right side of my set. After about 30-45 minutes of the TV being on, it disappears, so, I havent been too concerned.
I thought read something about 'lazy' lcd cells or something, is that it? Can it be fixed easily?
Any thoughts?
Try flexing the panel when the set first comes on with the lines. If they change or go away, there is a good chance that your panel is bad. It can sometimes be repaired by taking the back off and carefully placing a wedge between the frame and the edge of the panel while watching the lines in the picture. If the lines go away after doing this, then your panel is definitely bad. This repair could be temporary, but it may last until something else fails and you can buy a new one because they are so inexpensive.
Here's a list of things to check. You may wish to try unplugging the TV overnight to see if a "reset" fixes things. Also, are you seeing this on all inputs? I noted the various items you have in your "location".
Is it on the "TV" input as well - you can go there even if you don't have an antenna...
http://www.digitalhome.ca/forum/showthread.php?t=19694 Things to check.
I would flex the panel before taking the back off to see if it makes any difference. If it does, then I would take the back off and see if a wedge will work. The connections on the top (and sometimes the side) are just thin, flexible ribbon cables that are very fragile. You can also lightly tap the top and side to see if that makes any difference as well.
Discussion Starter · #6 ·
Its on ALL inputs...at first I thought it was something to do with the side that the line occurs on, bumped up to an outside (cold) wall, but, I dunno how much merit that would hold.
And 57, your advice and posts have helped me in the past, i appreciate it :)
What kind of technique would I use to 'flex' the panel? And do I do the tapping thing with the back off?
You can tap it with the back on or off. To flex the panel, I would hold the offending side with both hands and move one had forwards and the other one backwards, as though you were trying to twist it. Tapping the top and side is probably the most effective way, though.
Discussion Starter · #9 ·
UPDATE...
Now there is a single pixel GREEN line going vertical, top to bottom...permanently.
Is it worth it opening up the back? Tapping the top makes it go darker (its quite a light green)...I dunno, Im pissed, spent most of my extra $$ on Xmas, and now the TV goes for a crap!
I will NEVER buy a Toshiba TV again, this thing is only 3 years old or so.
You will find that all the TV manufacturers have similar problems with some of their TV's. Because of this, there is no more brand loyalty with customers, and the manufacturers don't really care because the next customer will have the same problem with his Sony, will get mad at Sony and will buy a Toshiba next time.
1 - 11 of 11 Posts
