1 - 7 of 7 Posts
Discussion Starter #1 (Edited)
I am looking to sell my JVC RX-888VBK AV receiver which has service me well for the past years. It's is in absolutely perfect working condition and includes the remote and manual.
I just replaced it with a soundbar which is a better fit for my small condo.
I am looking at getting $75 for it or $100 with a 5.1 "Quest" speaker system+stands. Pics available upon request, but everything looks just like new as I take great care of my stuff. The remote is also like new as I used a Harmony remote instead.
Official specs are available here: http://support.jvc.com/consumer/product.jsp?archive=true&pathId=5&modelId=MODL005010
This make a great main or secondary receiver if you are not looking for HDMI switching.
* 120 watts x 2 min. RMS, both channels driven into 8 ohms from 20Hz to 20kHz with no more than 0.02% THD, 120 watts x 2 min. RMS, driven into 4 ohms, with no more than 0.08% THD. 4 ohm Rated (FTC)
* 100 watts x 5 min. (2 Front, 1 Center, 2 Rear speakers) RMS, into 8 ohms, 1kHz, 0.8% THD
* DVD Multichannel Audio Compatible (5.1 channel analog input and 5 separate amps) for connection to existing and future multichannel sources such as DVD Audio
* Multi-Brand A/V-CATV-DBS Remote Control
* Dynamic Super-A for smooth sound reproduction virtually free of switching and crossover distortion.
* K2 Interface (all channels) provides better resolution ,enhanced ambience, and greater depth by eliminating distortion known as "jitter" and "ripple"
* 1-bit P.E.M. D.D. Converter (all channels) greatly enhances signal to noise ratio and dynamic range
* Dolby Digital/DTS decoders built-in for theater quality surround from digital sources
* Fully Discrete Outputs to ensure greater fidelity and longer life
* Digital Acoustics Processor (DAP), with 4 preset sound fields (DSP)
* 3D-PHONIC Virtual Surround Sound creates dramatic home theater sound with just two front speakers
* Text COMPU LINK will transmit text data carried by media like CD-Text and MD to display on your receiver and a television
* AV COMPU LINK provides simple one touch operation between your JVC audio and video components. For example, pop a pre-recorded VHS tape into the VCR and it will automatically power up your receiver and your television and then turn them each to the proper inputs.
* Enhanced COMPU LINK Control System
* Multi-Color On Screen Display simplifies control by allowing you to choose options from your television screen to operate your receiver
* Dot Matrix Fluorescent Display with Sound Pattern
* Line level Sub Out
* 3-band electronic S.E.A. equalization with 5 presets and 1 manual setting for each source to give you flexible tone control and minimize sound degradation
* Loudness switch, Balance, One-Touch Operation, Velocity-Sensitive Rotary Encoder Volume Control
* Front A/V Input with S-Video (Gold Plated) for the convenience of hooking up any A/V source quickly and easily such as a camcorder or video game
* 1 Assignable Coaxial Digtial Input that you can designate to any digital source
* 2 Assignable Optical Digital inputs that you can designate to any digital source
* 4 S-Video inputs (1 on Front Panel)
* 2 S-Video outputs
* 1 Composite Video output
* 2 Main Speaker Terminals
* 15 AM and 30 FM station memory with character input for each station
* Weight: 26.3 lbs
* Width: 17 3/16"
* Height: 6 3/8"
* Depth: 16 1/4"
* Banana Plugs for easy speaker connections (Main1/Main2/Center/Surround)
* High-Rigidity Z-Chassis
* Dolby Pro Logic in Full Digital Processing
* Center Tone Control
Discussion Starter #3
I prefer not to ship the receiver, but if I did, it would be the cost of the shipping which may be significant as the unit is pretty heavy (26.3 lb, according to the specs).
Shipping won't be cheap....it's light compared to my Sony DA777ES which is about 55 pounds. Thanks, but I will pass.
Dave
Discussion Starter #5
No problem. I am going to post it on Kijiji and Craigslist as there's been little interest here. I wanted to give the folks here first chance :)
Receiver
Sent you a PM
1 - 7 of 7 Posts
