CM GH6n3 optimized by nikiml
CM UHF net gain 14.2dbi VHF-hi net gain 9.85
CM covered by GPL v3 or later (http://www.gnu.org/licenses/gpl.txt)
CM see http://www.digitalhome.ca/forum/showpost.php?p=907404&postcount=2
CMD--OPT -s(470,6,24) -t(14.2,14.4) -s(174,6,8) -t(9.5,9) -n4 -a10 -r restart.log -L
CMD--OPT -F .2*ave_max_gain_diff+.8*ave_gain_diff
CMD--EVAL -s(174,6,8) -s(470,6,24) -a10
CM
CM Score -0.397421
CE
SY radius=0.003175
SY narod_surf_spacing=0.006
SY narod_spacing=0.012
SY feed=0.03776106' 0.02, 0.07
SY b=0.121252' 0.075, 0.25
SY a1=0.1945679' 0.07, 0.22
SY _G3=0.06374546' 0.006, 0.1
SY a2=a1+feed-_G3'this is to avoid self intersection since _G3 is to be > radius+2.5mm
SY a3=0.1321573' 0.07, 0.22
SY x=-0.07477662' -0.1, -0.06
SY g1=0.04301694' 0.002, 0.045
SY g2=0.04430498' 0.002, 0.045
SY g3=0.006236525' 0.002, 0.045
SY l1=0.3144561' 0.1, 0.6
SY l2=0.4490271' 0.1, 0.65
SY l3=0.5567192' 0.1, 0.65
SY n_h=0.08642624' 0.05, 0.14
SY n_f_dx=0
SY n_top_dy=-0.03529455' -0.06, 0.04
SY n_b_taper=0.0445677' 0, 0.1
SY n_top=_G3+a3+n_top_dy- n_b_taper/2'hat head size
SY n_f=x + n_f_dx'so the hat does not tilt behind the reflectors
SY narod_top = a1+a2+a3+narod_spacing+n_h'want to put 3 reflectors between z=very_small and z=narod_top +/- very_small, 1 reflectors around narod_top and 1 above it
SY dz3=0.1409803' 0.017, 0.15
SY above_below=-1
SY sign = abs(above_below)/above_below' may fail at 0
SY z3 = sign*dz3+narod_top
SY dz = z3/5
SY dz1=1.72834' 0.2, 2
SY z1 = (1+(dz1-1))*dz
SY dz2=1.733665' 0.2, 2
SY z2 = (3+(dz2-1))*dz
SY ay1=feed+a1
SY ay2=feed+a1-a2
SY ay3=feed+a1-a2+a3
SY ay4=feed+a1-a2+a3+b
SY az2=a1+a2
SY az3=a1+a2+a3
SY n_b_z=az3+narod_spacing
SY n_b_y1=n_top+n_b_taper
SY n_b_y2=n_b_y1+b
SY n_z_coef=0.7314852' 0.5, 1.4
SY n_zsz=0.4049281' 0.3, 0.55
SY n_0sz=0.4701482' 0.3, 0.6
SY n_x_diff=0.2752484' 0.15, 0.4
SY n_x = x-n_x_diff
SY n_z = narod_top*n_z_coef
GW 1 15 0 feed 0 0 ay1 a1 radius'#00f
GW 2 13 0 ay1 a1 0 ay2 az2 radius'#00f
GW 3 9 0 ay2 az2 0 ay3 az3 radius'#00f
GW 4 7 0 ay3 az3 0 ay4 az3 radius'#00f
GW 5 17 x g1 z1 x l1+g1 z1 radius'#0f0
GW 6 23 x g2 z2 x l2+g2 z2 radius'#0f0
GW 7 29 x g3 z3 x l3+g3 z3 radius'#0f0
GW 11 7 n_f n_top n_b_z+n_h 0 n_b_y1 n_b_z radius'#000
GW 12 7 0 n_b_y1 n_b_z 0 n_b_y2 n_b_z radius'#000
GX 20 010
GW 13 15 n_f -n_top n_b_z+n_h n_f n_top n_b_z+n_h radius'#000
GW 15 43 n_x -n_zsz n_z n_x n_zsz n_z radius'#D00
GX 40 001
GW 16 51 n_x -n_0sz 0 n_x n_0sz 0 radius'#D00
GW 100 5 0 -feed 0 0 feed 0 radius*.8675'#f40
GE 0
LD 5 0 0 0 24900000
GN -1
EK
EX 0 100 3 0 1
FR 0 0 0 0 800 0
EN
Hi NikimlTried optimizing GH6n3 for the repacked UHF/VHF frequencies.
Below are the html view and the nec code for the result.
html view
Code:CM GH6n3 optimized by nikiml CM UHF net gain 14.2dbi VHF-hi net gain 9.85 CM covered by GPL v3 or later (http://www.gnu.org/licenses/gpl.txt) CM see http://www.digitalhome.ca/forum/showpost.php?p=907404&postcount=2 CMD--OPT -s(470,6,24) -t(14.2,14.4) -s(174,6,8) -t(9.5,9) -n4 -a10 -r restart.log -L CMD--OPT -F .2*ave_max_gain_diff+.8*ave_gain_diff CMD--EVAL -s(174,6,8) -s(470,6,24) -a10 CM CM Score -0.397421 CE SY radius=0.003175 SY narod_surf_spacing=0.006 SY narod_spacing=0.012 SY feed=0.03776106' 0.02, 0.07 SY b=0.121252' 0.075, 0.25 SY a1=0.1945679' 0.07, 0.22 SY _G3=0.06374546' 0.006, 0.1 SY a2=a1+feed-_G3'this is to avoid self intersection since _G3 is to be > radius+2.5mm SY a3=0.1321573' 0.07, 0.22 SY x=-0.07477662' -0.1, -0.06 SY g1=0.04301694' 0.002, 0.045 SY g2=0.04430498' 0.002, 0.045 SY g3=0.006236525' 0.002, 0.045 SY l1=0.3144561' 0.1, 0.6 SY l2=0.4490271' 0.1, 0.65 SY l3=0.5567192' 0.1, 0.65 SY n_h=0.08642624' 0.05, 0.14 SY n_f_dx=0 SY n_top_dy=-0.03529455' -0.06, 0.04 SY n_b_taper=0.0445677' 0, 0.1 SY n_top=_G3+a3+n_top_dy- n_b_taper/2'hat head size SY n_f=x + n_f_dx'so the hat does not tilt behind the reflectors SY narod_top = a1+a2+a3+narod_spacing+n_h'want to put 3 reflectors between z=very_small and z=narod_top +/- very_small, 1 reflectors around narod_top and 1 above it SY dz3=0.1409803' 0.017, 0.15 SY above_below=-1 SY sign = abs(above_below)/above_below' may fail at 0 SY z3 = sign*dz3+narod_top SY dz = z3/5 SY dz1=1.72834' 0.2, 2 SY z1 = (1+(dz1-1))*dz SY dz2=1.733665' 0.2, 2 SY z2 = (3+(dz2-1))*dz SY ay1=feed+a1 SY ay2=feed+a1-a2 SY ay3=feed+a1-a2+a3 SY ay4=feed+a1-a2+a3+b SY az2=a1+a2 SY az3=a1+a2+a3 SY n_b_z=az3+narod_spacing SY n_b_y1=n_top+n_b_taper SY n_b_y2=n_b_y1+b SY n_z_coef=0.7314852' 0.5, 1.4 SY n_zsz=0.4049281' 0.3, 0.55 SY n_0sz=0.4701482' 0.3, 0.6 SY n_x_diff=0.2752484' 0.15, 0.4 SY n_x = x-n_x_diff SY n_z = narod_top*n_z_coef GW 1 15 0 feed 0 0 ay1 a1 radius'#00f GW 2 13 0 ay1 a1 0 ay2 az2 radius'#00f GW 3 9 0 ay2 az2 0 ay3 az3 radius'#00f GW 4 7 0 ay3 az3 0 ay4 az3 radius'#00f GW 5 17 x g1 z1 x l1+g1 z1 radius'#0f0 GW 6 23 x g2 z2 x l2+g2 z2 radius'#0f0 GW 7 29 x g3 z3 x l3+g3 z3 radius'#0f0 GW 11 7 n_f n_top n_b_z+n_h 0 n_b_y1 n_b_z radius'#000 GW 12 7 0 n_b_y1 n_b_z 0 n_b_y2 n_b_z radius'#000 GX 20 010 GW 13 15 n_f -n_top n_b_z+n_h n_f n_top n_b_z+n_h radius'#000 GW 15 43 n_x -n_zsz n_z n_x n_zsz n_z radius'#D00 GX 40 001 GW 16 51 n_x -n_0sz 0 n_x n_0sz 0 radius'#D00 GW 100 5 0 -feed 0 0 feed 0 radius*.8675'#f40 GE 0 LD 5 0 0 0 24900000 GN -1 EK EX 0 100 3 0 1 FR 0 0 0 0 800 0 EN
The antenna from my previous post still has good gain above 608 Mhz, and so if it is interference that is causing the problem, it probably wont help. Not sure about the filter.Hi Nikiml
Been using my GH6n3 antenna for about 8 years I think and it's performed quite well but the recent repack is probably causing certain channels to pixelate, even the strong ones. I'm wondering if your modifications will bring changes to the element and narod spacing. Also if an LTE filter would help because of the strong signals now being used that disrupt antenna performance.
Thanks,
Scorpio333
