1 - 2 of 2 Posts
The Canadian Radio-Television and Telecommunications (CRTC) will transition from epass to Access Key. This is a government-wide initiative that will continue to provide Canadians with secure access to government online services.
http://www.crtc.gc.ca/eng/file_faq1.htm
I wonder what hoops i will need to jump threw. In order to get at crtc.ca database.
Read ya l8r,
Al
Read ya l8r,
Al
You didn't need ePass to access the databse, so you won't need AccessKey.
These are authentication methods that licenesses use when filing applications and other offical documents electronically with the CRTC. It should have no effect on non-licensees.
That said, I note in the details that AccessKey can handle much larger file attachments, so that applicant will no longer be required to zip their file attachments. I wonder if that means that from now on, application data may or may not be zipped? If not zipped, then perhaps we could post direct URLs to indiviadual documents in the database, which would be cool.
1 - 2 of 2 Posts
