PREAMP NOISE FIGURES:
Marcoux's paper cites Wetmore+Schnelle's IEEE Trans on Broadcasting Jun2004 article,
The Performance of Antenna Amplifiers Used for Terrestrial DTV Reception"
(fol. link requires subscription..or a library):
http://ieeexplore.ieee.org/search/f...er&openedRefinements=*&searchField=Search+All
Although the article did not name manufacturers and part numbers, they did list the
manufacturer's spec value for Gain and Noise Figure in the same table as their Gain
and Noise Figure measurements.
I took an educated guess at matching up these results...which was fairly easy in many cases:
http://imageevent.com/holl_ands/files/ota
[The Preamp Gain table also includes measured NF values found in HDTVPrimer.]
Since worst Preamps appear to be antique B-T Suburban III and Voyager III models, I've always
wondered where Wetmore obtained the Preamps....perhaps after some were in use for many years???
After all, they were trying to assess what "typical" viewers were actually using....
But I think they might have been testing some "junk bin" Preamps removed by a local installer!!!!!
CECB/STB/DTV SENSITIVITY/NOISE FIGURE:
NAB sponsored a CECB (converter box) test:
http://www.nabfastroad.org/NAB-STV Digital Converter Box Evaluation/Manuals-summary-report1.html
Sensitivity was compared to the MSTV/NAB Funded Prototype.
Note that actual performance (number of stations actually received)
DID NOT CORRELATE
to either the measured sensitivity....or the number of ATSC A/74 Multipath Test Ensembles
(actual "worse case" field captures) successfully decoded.
LG (Zenith/Insignia) was the ONLY manufacturer that submitted "Noise Figure" test data (pg28)
in the (mistaken?) belief that they had to verify conformance to the FCC's max NF<14 dB spec:
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=820977&native_or_pdf=pdf
https://fjallfoss.fcc.gov/oetcf/eas...N&application_id=406918&fcc_id='BEJ9QKE00710'
And, of course, all CECB manufactures had to verify conformance to -83 dBm sensitivity spec,
which is NF=8 dB away from theoretical sensitivity (-106.2 dBm Noise + 15.2 dB CNR = -91 dBm).
FCC OET (Engineering Group) conducted tests, including Noise Figure (implied from Sensitivity),
for 2005/2006 vintage STB/DTVs (manufacturers unidentified):
http://www.fcc.gov/oet/info/documents/reports/TR-05-1017-ATSC-reception-testing.pdf
BTW: When I find an unexpected sensitivity (aka NF) result, I immediately suspect that there
might have been a low level RF leakage path which can either improve sensitivity...or degrade
it due to multipath....which is why it is important to have confirmation from alternative labs.
Attenuating the main signal to "prove" the leakage path doesn't exist is invalid...the leakage
path might be only one or two dB below threshold...which still affects sensitivity measurements.
ANTENNA SPECSMANSHIP:
BTW: There is probably a lot of "specsmanship" re Marcoux's antenna "tests". For example,
HBU-22 "specs" simply say 4.1 dBd Hi-VHF and 7.3 (not 7.2) dBd UHF Gain without
saying which channel nor whether it was guaranteed minimum (fat chance), some
sort of "average", "typical" (whatever that is supposed to mean) or the max Gain
found somewhere in the band (very likely).....YMMV....
And since Marcoux didn't explain what HE was measuring, perhaps it was the
WORST Gain found somewhere in the band.....maybe, maybe not....YMMV....
