1 - 1 of 1 Posts
I pulled this info but I have options X4A(4323) and Q4A(4322). I assume I'm on 4323, is that correct?
You can temporarily change your channel map to match the type of LNB you have. You may not get the best results as the focal lengths are different for the 60 vs 75 dish.
Press OPTIONS, 1, 1, 2, 2
Select X4C (4321) for the Triple xKu LNB
Select Q4C (4320) for the Dual Quad LNB
This will let you at least test the setup. Getting the correct LNB would be best.
1 - 1 of 1 Posts
