Hello. I was hoping anyone with a telecom background, or understanding of telephone data panels in general could shed some light on this subject.
I'm in the process of moving my modem from my 2nd floor bedroom, to a shelf on the 1st landing wall going down to my basement. The logic being:
1) Wi-Fi signal will be more central to the house
2) I've run Cat6 cables from 2 of the second floor rooms - down into the basement landing wall where the modem will be moved (so I can have Ethernet access for both rooms.)
3) I can now more easily run Cat6 cable from the modem to my basement (along side the basement floor joists, through the sub-floor, into my living room's wall where another streaming box is.
In my case, because my modem is in an upstairs office, and we're using Rogers as our phone service, during installation, a Rogers tech had to install a 3 way phone splitter "biscuit" on the floor. He needed to interface the phone line from our wall, with our phone, and to the modem - basically splitting the phone line using the biscuit, so that both modem and phone could be using the same phone line. SEE: 3 Way Biscuit.JPG.
Telecom people know that a phone line only needs 2 wires, or 1 pair to be punched down at a 110 terminal in your data panel box, in order to send/receive voice. Usually it's the blue/white wire for the T (TIP) and solid blue wire for the R (RING) If you look at this image: Mediasync CSH-C810.JPG — NOTE: There are 2 connected phone lines here.
The 1 on the left goes to our upstairs kitchen phone wall jack, the 2nd line on the far right (with the green tape) terminates to a wall jack in the upstairs bedroom where the modem currently is.
See the far right strip labelled with 4 vertical "TR" markings
1 TR (This is where the 2 wires are punched down on the panel, terminated at the upstairs office phone wall plate, where the RJ11 jack plugs into the Rogers Ignite modem's TEL 1 jack)
I'm assuming that each pair or set of TR (4 in total) is for having 4 separate phone lines, if required.
2 TR — additional separate phone line
3 TR — additional separate phone line
4 TR — additional separate phone line
QUESTION: If the Rogers Ignite modem requires a phone line in TEL 1 on the back of the modem for phone service, do the 2 phone wires punched down in the 1st TR position have to connect to TEL 1 on the Rogers modem?
OR, can the 2 phone wires originate from one of the "EXPANSION" strips on the left? I'm not quite sure about this. As I understand it, the "TR strip" for Tip & Ring on the far right, governs all other connected phone lines that are subsequently punched down into the expansion strips to the left.
Basically, does it matter what strip the Blue/White | Blue wires are punched down, in order to be connected to the TEL 1 input on the back of the Ignite modem? MUST they be connected to TR1, and be terminated via phone plug — into the modem?
Thanks for any input you can give.
