1 - 2 of 2 Posts
Hi All
first please let me thank you all for letting me be part of this forum.
i have a question about my DSR 205 receiver. it has started losing signal on some chanels. the signal light keeps changing from green/red/green/red. not on all channels but seems to bee in groups of channels. my other receiver is just fine. i switched cables to the dish with no change. borrowed a power supply from a neighbor and no change. any ideas on how to fix this without shipping it to SD? thanks in advance for any ideas.
You could try a factory reset options 6-7-7-8-6 enter .... be sure to put rec on channel 284 when it comes back on and you will have to call for a refresh to get all channels back.
if after that the rec is still intermittent you can call SD and tell them what you have tried they will send you a replacement for only a shipping charge.
1 - 2 of 2 Posts
