1 - 10 of 10 Posts
Hello:
I have a iPhone SE. I'd like to use it with a tablet simcard...I use Magicjack and have the app running. For all the calls I make/receive, a 1 or 2 gig plan would suffice. Does anyone know of a telco that will sign up a tablet plan for use in a cell phone, without having to be an existing customer ??
I don't need minutes nor texts. Just pure data.
Airtime and texts are a red herring. They don't need to be used. Just look for any plan that provides the best deal on data at a reasonable price. Just keep in mind that 3G data is significantly slower than 4G data but 3G should be good enough for VoIP like MagicJack.
Zoomer is the cheapest I've seen so far.
https://www.zoomerwireless.ca/tablets
It runs off the Rogers LTE network.
$15 for 3GB of data
$25 for 5GB of data
$35 for 7GB of data
And if you're primarily using this for MagicJack, seriously take a look at Fongo instead. So far it's the best VOIP I've used. Fongo phone usage is 1 minute of talk = 1mb. Granted the texting isn't free but it's only $9.99 unlimited texting for 6 months. Personally I use my Google Opinion Rewards to pay for it so it doesn't really cost me anything.
Hope this helps.
Zoomer fine print seems to be
Tablet Data plans are only available to existing wireless customers.
1 - 10 of 10 Posts
