I have Windows 7 Ultimate. I often use the msconfig command to check on startup programs and other things.
I tried uploading some ringtones and wallpaper to my W385 cell (without success) and in doing so, I now get this error...
I've tried going into safe mode even, and even there, it will load briefly, but not allow you to make any changes, and then shut down with the same error message above.
Very confused as to what could've caused this. I'm not sure why installing a legit driver would disable my System Config Utility.
Any suggestions at all? I've been googling this for 2-3 hours now with no luck. I'd hate to repair or re-install for such an insignificant problem, but I don't know if this is a sign of other problems or not.
Thanks in advance!
I installed motorola drivers today and that's about all I've done. I have since uninstalled them, cleaned the registry with registry mechanic 9, restarted the computer... I just cannot get "msconfig" to load up anymore.System Configuration Utility Has Stopped Working
Thanks in advance!
