1 - 2 of 2 Posts
I am having some difficulty with mounting a swing away type TV mount.so the TV is centered on the wall while not extended.
The mount is an AVF Group UL805 and isn't listed on the AVF website. The illustration in the assembly instructions shows the TV centered when extended. The swing arm is off to one side when it isn't extended.
The want the TV to be centered when not extended from the wall.
Should they get a different mount? it is a bank in the public area.
The TV is a Samsung PM42C450B1D
would there be a website that may have some sort of template.
I have the wall measurement and the distances of the stud spacing.
The want the TV to be centred when not extended from the wall.
The articulating arm can be moved left or right to re-position it on the wall mount; you can move it to one end or the other to cause the TV to be centred when flush to the wall.
PS. I have the same mount and TV in my bedroom.
HERE is a link to the instructions.
BTW - they list the UL805 under "PUL805PB1-C"
1 - 2 of 2 Posts
