Can someone suggest a good WiFi extender that will work with my Home Hub 3000?
Or could you please suggest a device or setup that will increase speeds on the 2nd floor.
I tried the Netgear Nighthawk x6 Tri- Band WiFi Mesh Extender (AC2200) and could not get it to work with the HH 3000. I followed all the setup instructions and tried using a browser setup and then the iPhone setup procedure. No luck.
Then I spend way too long with Netgear tech support and was never able to connect the 2.4G and 5G WiFi networks to the HH 3000. Near the end, as they were running out of suggestions, I was guided to change the backhaul channel settings but never found what they were or how to change them on the HH 3000. Bell tech support offered no support for a 3rd party device. I don't want to waste any more time with the Netgear AC2200.
I would greatly appreciate hearing from anyone using the HH 3000 and a WiFi extender or booster.
Which device is working for you?
Background.
I'm on Bell Fibre and with the HH 3000 getting the following speeds on different floors
Basement (where HH 3000 is located)
Download: 300 Mbps (Macbook Pro) 550 Mbps (iMac) (All computers on OS X 10.13.6)
Upload: 600 Mbps (MBP) 700 Mbps (iMac)
1st Floor
Download: ~ 175 Mbps (iMac)
Upload: ~ 175 Mbps (iMac)
2nd Floor
Download: 4 Mbps (MBP)
Upload: 2 Mbps (MBP)
Background.
1st Floor
2nd Floor
