I recently had Telus Optik TV + Internet installed over fiber. I decided I didnt want or need the supplied Actiontec T1200h, as my PVR and STB's were connected through Cat5E, so I set out to run everything off my Asus RT-AC56U instead. After much searching I saw a lot of conflicting posts about whether or not this was even possible, so I thought I would post my own (successful) experience and share the steps with others.
First off, I am running Merlin firmware on my RT-AC56U, but that shouldnt matter, as I believe most newer Asus routers do have the IPTV config tab under the LAN settings, and none of the other Merlin-specific features matter to this setup.
Secondly, I did have the RT-AC56U connected as my router for all network devices via the Port 1 Bridging off the T1200h prior to changing the setup to eliminate the Actiontec, but again, that shouldnt matter. I DID NOT clone the MAC address of the Actiontec like some other posts say you have to do, so that should not be necessary.
My network is connected as follows:
Alcatel Lucent ONT --> RT-AC56U WAN
IPTV tab settings in RT-AC56U config:
ISP Profile: None
STB port: LAN4
DHCP routes: RFC3442 & Microsoft
Enable multicast routing: Enabled
Enable efficient multicast forwarding: Enabled
UDP Proxy(Udpxy): 0
After that, all I had to do was reboot the Telus Optik TV boxes. Everything is connected and working, the PVR recordings are available on the other STB's, the streaming quality is every bit as clear as it was before, and the whole system just feels more responsive now (i.e. the channels seems to switch faster).
RT-AC56U Port 1 --> D-link 16-Port Gigabit Switch --> all my wired network devices and 3 other AC routers as AP's
RT-AC56U Port 2 --> Desktop computer (on same VLAN/network as Port 1)
RT-AC56U Port 4 --> Trendnet TEG-S80g (8-Port Gigabit switch) Port 1
TEG-S80g Port 2 --> Telus PVR (Cisco ISB7150)
TEG-S80g Port 3 --> Telus Digital STB (Cisco ISB7100)
TEG-S80g Port 4 --> Telus Wireless STB Access point
ISP Profile: None
STB port: LAN4
UDP Proxy(Udpxy): 0
