I bought a used set of 5.1 Mission M2V a short while ago.I'm happy with the speakers,but I'm noticing a low pitch vibration at certain frequencies from the subwoofer.It's not noticable most of the time.I took the sub box apart and found a piece of wood had come lose,but that wasn't the problem.It appears to be the speaker itself.There is no visible rips or damage.
Is it worth trying to find a replacement speaker , or just replace the whole sub ?? Is there a store in Calgary where I might find a replacement ??
Do I need a Mission repacement speaker , or a speaker with similar specs ??
I would like to go with the cheapest option.
Sorry for all the questions.
