1 - 8 of 8 Posts
For anyone else using the new Mediaroom setup is the screen randomly changing to the Info screen while watching TV without pressing anything on the remote?
I doubt this is normal behavior, but I am putting this thread up to see if I'm the only one having the issue. We might need to wait until it rolls out a little more wide spread to see if it's common.
This has happened while the remote was just sitting on my chair too. Very random. Is there a bug fix list for later versions of Mediaroom floating around?
· Super Moderator
This is a Mediaroom bug that first appeared in version 1.6.25314, which is what Aliant uses and also occurs on Bell and MTS. Here is a link to the MTS thread on the topic.
http://www.digitalhome.ca/forum/showthread.php?p=1166836
I believe this this still occurs on version 2.0.26496 that MTS uses, but I've gotten so used to it I can't say for sure.
There isn't an official bug fix list that I've seen.
1 - 8 of 8 Posts
