1 - 4 of 4 Posts
· Super Moderator
I'm not sure if the USB port could simply be used as another input from say a computer. Most times people connect a USB stick, which "passively" contains the files that the TV then "plays".
If you wish to play something from the computer, you usually use one of the other inputs - HDMI, composite, etc., depending on the output capabilities of the computer.
1 - 4 of 4 Posts
