i have had this tv for just over a week and it was working fine until tonight.
I was watching TV tonight and after about 5 min of viewing the screen suddenly went black for a second, and then again, and then it seemed ok and then again and again and on and on.
I checked the high def box and it seemed ok each time it went off and I can only think it is the tv itself. I have it hooked up with a hdmi cable I had purchased from Tiger Direct about a year or so ago. The HDMI cable was cheap and now I wonder if it is the problem, although for a week and a half the TV worked just fine.
what do you think?
what do you think?
