1 - 2 of 2 Posts
Hello sirs and ladies!
I'm having an issue that is really starting to piss me off. I have a 4100, a 9242 and a 6131 all on the same dish. I have no issues whatsoever with the 4100 and the 9242. With the 6131, For some reason I am only getting one satellite. One day I was only able to get 91, now I can only get 82. I've tried different receivers in this room with the same result. So my only guess is that it is a switch issue. but everything else is on the same switch and running with no issues?
I ran a check switch and I got this message, "The check switch test has found you have fewer satellites than previously detected." Lame.
Anyone have this issue before. Might there be a quick fix for this?
Thank you!
1 - 2 of 2 Posts
