I have a CM4221HD (new ver, didn't do the mod except bending a little) in the balcony, 2nd floor in an apt balcony, surrounded by other buildings in a flat terrain (sea level) in an urban area in the Greater Vancouver area.
With the Wingard AP8275 preamp, it helps to pick up the Bellingham PBS K24IC-D, but barely, and not on a bad day.
But I need to feed a few tuners though: 2 TVs, one Hauppauge Broadway, and occasionally Hauppauge USB tuner (and in the past, Bell 9242 PVR w/ ATSC tuner), so I need a 1 - 4 distribution. I bought a "for cable" distribution amp from BestBuy, and it didn't seem to help, plus it seemed to be worse, and I am not sure if it's getting some DC interference from the DC injector for the Wingard amp or what (I placed it before that of course), or it has some prob (IIRC it was an open box before, a house brand by BB).
So right now I am using a passive (sat grade) 1-2 splitter, and getting by, and PBS doesn't come in all the time. I am looking for a better but hopefully not expensive solution for a 1-4 distribution amp.
I am ok with electronics and can also go the DIY route, if the parts are not hard to come by, if I can save some money. As long as the result is good (i.e. low noise, suitable gain).
Also, if I upgrade the amp from Wingard (at that time, it was the most reasonable choice for bang for the bucks, there are better preamps but they cost a lot more), would that help a lot? There is no way I could place the antenna any better as I don't live high enough (20' off ground).
Thanks in advanced!
