RCA TVPRAMP1R Amplifier
I received my second RCA preamplifier on Monday. Unfortunately, I got home too late to do any more than bench check it. Ordered Thursday night –delivered on Monday.
Yesterday, I dropped my tower and removed the PCT MA2-M from my 91XG.
I also removed the PCT MA2-M from my Antennacraft Y10 7-13.
I made up new antenna cables w/boots and installed the RCA TVPRAMP1R Amplifier on the mast between the two antennas. I configured it for separate inputs with the FM trap selected.
(It works better vertical!)
I decided to use the supplied power supply/inserter. The run from the garage to the amplifier is ~125’ through copper coated steel RG-6 so I was expecting I might encounter too much voltage drop. Turns out, it works just fine. The RCA draws <80 ma and my 3 PCT MA2-M’s were drawing almost ten times as much.
While I was at it, I decided to remove my mast mounted regulated power supply and supply my FM antenna through its dedicated coax. I also removed the 125’ of RG-6 I used to send power to the PCT amps. Ready for another antenna? I must have hooked something up wrong because when I got done, TV worked great but I lost my FM feed. I’ll be trouble shooting that tomorrow.
My Winegard AP-2870 overloaded with my 8-Bays on my push-up mast, but it overloaded a lot worse on the tower with the 91XG, so I was half way expecting on the tower the RCA might overload as well. No such luck. Last night and all day today it’s been rock stable with no signs of overload what so ever. When I was first setting up my system, because of the big price difference, I never would have considered buying the much cheaper RCA amplifiers. Just shows to go ya!
Subjectively, I think the RCA is out performing the PCT drop amps. especially on VHF. Rescanning I’m picking up 1 low VHF channel, 1 high VHF channel and several UHF channels that I haven’t received in the past. Of course I’ll have to learn new languages to understand some of them. The RCA is specified to have 1 dB more gain on VHF & 7-8 dB more on UHF so that could be the reason with my long cable runs. The PCT’s are specified to have a Noise Figure of 2.7 dB (avg.) & 4.0 dB (max) with no distinction between VHF & UHF so it could be that I’m seeing a NF advantage. My main concern was with overload from my two strong local stations and that doesn’t seem to be an issue with either of the RCA’s that I have inline. I would sure like to know where the 1 dB compression point is reached with this design.
If we can tear majortom away from his “boat anchors” long enough it will be interesting to see how his performs.
