1 - 2 of 2 Posts
Hi guys, thanks for the ongoing help with my new canon xsi dslr, Here are some more pics just taken
Please feel free to give suggestions and advice based on the exif info.
Taking the kids to a santa parade tonight and was wondering what settings ( modes,shutter speed and iso ), you think I should be in with my 55-250mm lens ?
Cheers
Banned
Opps read this late
Usually you don't need a zoom lens unless you are far away.
if you are right at the side walk more wide angle to mid zoom.
If you are not using a flash crank the iso up to 1600 or higher if you can and post process the noise.
Good luck.
1 - 2 of 2 Posts
