Most receivers that utilize RF technology can be "paired" with one remote so that you can use RF even with several different receivers in the home/area....But I disabled mine, because with 3 receivers my 830 will interfere with my others.
Thanks for this info. A question you my be able to answer: with Shaw only offering ‘rentals’ with regards to the 800 series replacements, and then on ONLY one unit (many like me have five, owned 600 series devices), will I be able to just say ‘no’ when Shaw wants me to change to a DSR830, and continue using my ‘owned’ units until the final conversion is done? I’m considering just winding down and eventually cutting my satellite ties….not a big fan over renting. Thanks.The remote would be the same model you were given with your 6XX, there weren't any remote updates done for 8XX (though a couple of years ago we did get the TV pairing instructions screened onto the back, that's the only difference).
I think Shaw has no choice but to allow you to do this, but I'm wondering what service are you going to?Thanks for this info. A question you my be able to answer: with Shaw only offering ‘rentals’ with regards to the 800 series replacements, and then on ONLY one unit (many like me have five, owned 600 series devices), will I be able to just say ‘no’ when Shaw wants me to change to a DSR830, and continue using my ‘owned’ units until the final conversion is done? I’m considering just winding down and eventually cutting my satellite ties….not a big fan over renting. Thanks.
You can purchase a new unit from SD, 830 was 299 plus tax. As well, since I purchased my unit, my 630 will not be de-commissioned after 30 days (if you opt for a free rental that is what happens to the unit you replace). You could also buy used units cheaper (provided it was not a rental, and is clear of any charges) to add to your system.Thanks for this info. A question you my be able to answer: with Shaw only offering ‘rentals’ with regards to the 800 series replacements, and then on ONLY one unit (many like me have five, owned 600 series devices), will I be able to just say ‘no’ when Shaw wants me to change to a DSR830, and continue using my ‘owned’ units until the final conversion is done? I’m considering just winding down and eventually cutting my satellite ties….not a big fan over renting. Thanks.
Can you be able to purchase 800 series receivers as well I believe they are 99 or something or only 830 series is on purchase option?You can purchase a new unit from SD, 830 was 299 plus tax. As well, since I purchased my unit, my 630 will not be de-commissioned after 30 days (if you opt for a free rental that is what happens to the unit you replace). You could also buy used units cheaper (provided it was not a rental, and is clear of any charges) to add to your system.
I assume you can purchase the 800 as well. At the very bottom of https://www.shawdirect.ca/hardwareupgradeCan you be able to purchase 800 series receivers as well I believe they are 99 or something or only 830 series is on purchase option?
