1 - 7 of 7 Posts
Hey all, My parents have older Star choice at my parents farm. (In my name tho) and they just phoned me and ask if I was still getting my Calgary Global and CTV Calgary stations.. But since I'm on Telus. Its different, But my channels are fine..
There box is not showing them, They getting red light on both channels, But now they getting Edmonton feeds for some reason. They are using 2- 401 Receivers..
Since I'm on Telus tv. I said I am getting my Global Calgary and CTV ok. It could be just something has happened at Shaw Direct and or there Global/CTV feeds are down maybe.
Just wonder if anybody else in Alberta tonight is getting the same issue..
Alright thanks QCK. Strange tho both there (2) 401 receivers are not getting Calgary feeds, But are getting Edmonton feeds ok tho.
Discussion Starter · #5 ·
It could be, but single/quality was reporting around 80+ off channel 299.. and around 72+ for most other channels.
But I'll mention that to them tomorrow. Maybe ask SD when call in if the dish could be off a bit. Thanks for suggestion :)
Discussion Starter · #7 ·
yeah I guess Star choice er Shaw direct was having some issues and or Global/CTV Calgary had some issues..
Thanks. Good that I/parents aren't only one that had that small issue..
-Chester
1 - 7 of 7 Posts
