1 - 3 of 3 Posts
I'm replacing the Telus supplied SE567 with a TD-W8960N and need some advice setting it up.
So far i've found that Telus use 0,33 and IPoA as apposed to the PPPoE i'm used to configuring so its proving difficult, i can get the modem to connect in bridge modem direct to my pc but i can't get it to use NAT so i can share the connection :confused:
Any advice would be greatly appreciated!
1 - 3 of 3 Posts
