1 - 3 of 3 Posts
Hi!
I'm searching a multiformat television that can handle signal in HDMI in 23.98/50/59.94
It's for a post-production facility where I can work on job in 25 and on 59.94. I'm searching a consumer television that can handle that.
Most of compagny doesn't say those specs, but I know that some can play different format.
Someone can help?
You might want to look into Sharp. My Sharp Aquos handles 25 Hz PAL-N and 24 Hz movie video. Isn't 59.94 the frame rate for analog NTSC colour video? If so any analog capable TV should be able to handle that. 23.98 is the frame rate that's used to convert 24 fps film to NTSC colour.
1 - 3 of 3 Posts
