SDV appears to be active in Fredection. I noticed a change the Diagnostics Menu of my DCT to some of the channels after noticing some goings on last week. For several days the Screen Saver HD Channels where showing not authorized.
They returned on Thursday now appear to be on 24/7. They don't seem to off air during the peak times the sport pack were active.
To check via the Diag Menu (power off via the front panel while tuned to one off the channels, quickly press select twice) make you way to the current channel info if you have dual tuner it may appear on page two.
Select the Fireplace or Sunset channels and turn off your DCT right away press the select button twice. Make your way to the current channel info channel numbers for SDV will appear as 65535 in that menu.
The SDV stuff on page3 is for MOTO's version SDV not Cisco's so we may not ever see the SDV info there.
I checked several channel and several had this 65535 as there channel number.
I seen the 65535 channel ID the SD versions of the Screen Saver channels and SCHD1 SCHD2 over the weekend. Today i see this on some other channels about 4 out the 10 or so I checked. Other channels that appear to be on SDV so far. I-Channel, DW, BNN . I know I looked a while back at some of these and they did not show the 65535 channel number.
So if you like me have nothing better to do with your time or even if you do and are just waiting for the channels that we are missing DCT to see if you now see the same.
Lets all hope that soon many new (or new to us) channels will finally be upon us.
Cheers,
DW
Cheers,
DW
