1 - 3 of 3 Posts
my dish fell off the side of the house so i put it back up and when i did i think the switch got messed so i changed it and when i did i had signal on both 91 and 82 until i wired the switch back in.... the problem im really having is that when i checked the switch it said that if i continue i will delete satellites and so i continued... just wondering how i get thoes satellites back? do i do a hard reset???!! im sooooo lost and flustered any help would be amazing!
Well as you said you have already run a "Check Switch" I can only guess that the Dish is not aimed correctly yet.
Go back to the basics, aim the Dish with a line directly to the 91 LNBF, peak the signal, then connect the switch and run the "Check Switch" again.
If you are a Rental Customer, call Bell, your Service Call is covered under warranty.
1 - 3 of 3 Posts
