1 - 6 of 6 Posts
Can anyone fill me in on Sasktel's 3G data pricing for internet?
Why would the Novatel Wireless MC998D have a system admin. fee of $6.25 per month while access to the 3G network via a tablet (iPad) has no monthly admin. fee?
And why 5 GB of data for an iPad is $35.00 compared to 3 GB of data for a laptop costs $60.00.
Why the Telus products for 3G internet modems (hub, sticks, etc.) have none.
Am I missing something here? Isn't data just data no matter how you receive it on your end? Or does your hardware make a difference as to what you are charged?
:confused:
Sasktel is also the provincial "crown" that also does internet / TV / cell phones etc......
I guess I should have said - switch to rogers - and access - this would make more sense. or Rogers and Shaw if you live in S-Toon
that's some well thought out responses there KC1974
as for the price differentials, it's different bundles, some of which are partially dictated by the hardware manufacturor. you'll also see the excess mb charges are different between the plans
I can check to see if there's a more "official" answer if you like
You're more likely to use up your allotment of data with a data stick (since you'll be using it with a laptop) than you are on an iPad (which can't do as many things with cellular data as a computer can). It's that simple.
1 - 6 of 6 Posts
