1 - 3 of 3 Posts
I have the bigger sibling T240HD.
Overall quite happy with it.
If you're using it for OTA, only drawback is current guide info only. No future.
Though I think it's tough to find something with a full guide (or even just a single 'up next' thing) in this size range.
The tuner is quite sensitive, too.
Also note that wall mounting is no-go. Unless you buy the special bracket which essentially holds it up on the wall like a "torch holder" or a sat dish mount.
1 - 3 of 3 Posts
