1 - 2 of 2 Posts
i have a 46 inch Samsung which i bought almost three years ago and for the last 4-5 weeks when i start the tv from the remote i am able to hear a click but nothing happen for almost 40 seconds and after that i hear another click and the light on the tv flash ( red ) and after that in 10 seconds the tv will start.Can you guys help me with this issue and if somebody have has the same issue.There is one think what i never try and that is to press the button on the tv direct which i never done that but i will try it tonight.Please i need youe help.Many thanks.
Sorinel,
As it is out of warranty it is time to call a service technician. The symptoms indicate a power supply problem and the most economical solution is replacement of a few capacitors. More expensive would be complete replacement of the power suppy module.
Do a search on this web site for a technician that others have used with success to see if they are in your area.
1 - 2 of 2 Posts
