1 - 3 of 3 Posts
My son turned on the TV tonight and we can't get sound. We just tried playing a DVD and get sound from that on our surround sound, but no sound through the TV. We have a Bell ExpressVu PVR hooked up through HDMI cable.
Has anyone else experienced this problem? Can you offer help? We cannot get sound when trying to watch TV through the PVR (not through the surround sound or the TV).
Rodgers Family
· Super Moderator
Please advise us of the makes/models of all your equipment and how each piece is connected to each other piece.
It sounds like you have a Home Theatre in a Box (HTiB) or A/V receiver (AVR)? How are your devices connected to this item? Are they connected "through" the TV or directly to the Surround Sound (should be the latter - probably optical/TOSLink cable from the PVR to the Surround Sound System)? Is the surround sound system on the correct input to listen to the PVR? Reboot the PVR?
Here's the FAQ on Cables & Connections:
http://www.digitalhome.ca/forum/showthread.php?t=76085
Here's a post useful for those new to this - FAQs, Search Tips, Optimization, etc.
Your post has been moved to a general section since we're unsure where the problem lies.
Thanks - problem solved
We woke up this morning....and there was sound. We're not certain what happened, but everything seems to be fine now.
I'll give more details if I post again.
Ellen Rodgers
1 - 3 of 3 Posts
