My 46" tv is currently strapped to the stand with some rope! The plan it to utilize the threaded holes for the wall bracket and with some aluminium strip from Home Depot, fabricate a bracket that will bolt onto the TV and be screwed onto the stand. I estimate about a 2 hour job including the time it takes to go to HD and back. I have seen commercial brackets, usually designed for wall mounts primarily and only as stand mounts as an after thought and I am sure they work well but IMHO are overkill for my childless household and are too ugly and expensive.
