We're in a new build home, and I want to run some Cat5e and speaker wires to exterior walls. I'll run them from the basement to the family room, and from the attic to a spare bedroom/office. I have plenum-rated cables for the attic. I don't need to go through a cold air return, and I'm obviously not going to use the warm air ducts.
I have some retrofit low voltage plates, but I'm wondering about the best way to fish the cables. Should I try to get the cables between the inside face of the drywall and the vapor barrier (and how the heck would I do that), or just run it though the insulation and pop back through the vapour barrier at the wall plate?
I'm guessing the latter, and then seal around all penetrations through the vapour barrier, but with caulking, canned spray foam, or something else?
