Thanks for the info MarshMalo about the 360. I've been wondering how the 360 would fair With the Optik system. Your info will save me from having a minor freakout.
dpolites, do I require a STB box at each SDTV or are they wired directly to the coax. If a "box" is required what is the cost per SD set.Telus uses the existing coax in your house as the network cable. So if things are wired properly with coax, they likely can just use that and avoid running network cable around.
Yep you need an STP at each TV. Not sure if their are any deals going on for boxes right now or if you can negotiate a deal but standard rate is $10 a month for the receivers, $15 for the PVR receiver unless you on 3 year contract then no charge. For me, I did the 3 year for the PVR and bought my second STB for 149. Then no rental charges.dpolites, do I require a STB box at each SDTV or are they wired directly to the coax. If a "box" is required what is the cost per SD set.
That is comparing a apples to oranges since Optik uses Mpeg-4 which is about twice as efficient as Mpeg-2 which Shaw uses for it's TV channels.I think I read that Optik TV HD is 6 mbps. How does that compare to the Shaw feed or is that comparing apples to oranges?
I know I still get a little annoyed by what I would also call artifacts. I didn't see them when I was on Shaw's Motorola boxes, but I do see it on Telus. It is not really bad, but still to me it makes it look like the picture isn't as clear as Shaw. I notice on SD and HD channels. I only had it installed 2 weeks ago so I am still getting used to it. Seems like it might be worse when using HDMI, which Telus says still isn't officially supported...??? Maybe somewhat better using component cables. Just my 2 cents.Sort of related topic, can anyone comment on the amount of motion artifacts you are seeing with current Optik/Mediaroom configuration on TTV? When we first got TTV a couple years ago on the old SA 330 box, there seemed to be a distracting amount motion artifacts, evident for example if you were watching a newscast - announcer in foreground against a stationary background. Parts of the announcers face seem to move slightly out of sync. Other effects are the picture blurring with fast movement, for example on hockey telecasts. I've read these are some of the motion artifacts due to the way MPEG compression works. Since getting upgraded to Optik with the Cisco PVR and Mediaroom, thess effects seem to be less noticeable. Perhaps with MPEG-4 and more bandwidth, the artifacts are less (or maybe I'm just getting used to it). Comments anyone?
Check out the following post on this topic. It's in the SD forum, but it is perhaps applicable:...Seems like it might be worse when using HDMI, which Telus says still isn't officially supported...??? Maybe somewhat better using component cables.
