Yes, RF is the default.Do the ignite STB boxes and remotes not have an RF option as well as the IR?
The Harmony Elite remote uses the Harmony Hub to communicate with devices so it is compatible with IR, bluetooth and wifi remotes as noted above. The Elite remote is a more expensive version of the Companion remote that also works with the Harmony Hub.My Harmony remote is the Elite model which I believe is capable in both RF and IR.
AFAIK, there isn't a manual per se, same as a lot of electronics today. There is a knowledgebase and FAQs on Rogers' forum/website which has tips on how to do things:Is there anywhere I can find a proper manual for the XiOne box?
For example, I see a few LED (?) in the front of the box but I have no idea what they are.
Probably not. I counted 6 LEDs. Like I said, they never lit up. I will investigate and report back.If "they" are not on, then "they" may be the IR eye of the device?
I can notice the difference maybe because my TV is 85-inch.The difference between 1080i and 1080p should not be that noticeable except in fast action scenes such as those found in live sports. The difference is probably due to aggressive lossy MPEG2 compression used by legacy TV services which degrades picture quality. Newer IPTV services usually use H.264 or H.265 compression which has less picture degradation for the same amount of compression.
