1 - 6 of 6 Posts
Im build my HT and plan on putting components behind me so I was thinking about the harmony 890 so I dont have to point the remote backwards
do I need an extender?
what are they for? (if your in the backyard or something?)
It's an RF extender with four ports and picks up the RF signal from the 890 remote and converts it to IR to operate your devices. This extender is usually packaged with the 890 but not the 890 Pro. Also comes with 8 IR blasters on 4 8' cords which plug into the ports. Mine work well up to 50-60 feet.
ok so that leads me to belive if I just get a 890 pro or an 890 off ebay that will not work for me?
once it goes RF you need something to put ti back to IR?(is that what it is?)
I need this extender?
ok maybe I should just ask
I need a remote to control my media player and AVR that will me behind doors
what should I get?
thx
1 - 6 of 6 Posts
