1 - 5 of 5 Posts
Just had my Harnmony 550 replaced due to the channel + key not functioning (or at least only working occasionally). With the newer 550 the screen seems a lot dimmer. Any way to increase the brightness?
I still have the old unit; however while I can still use it, I can't update it in future as they have locked it out.
Peter
I've never heard of a remote being "locked out" before. I had an issue with my 880 with one of the buttons. Logitech sent me a replacement. I still have the remote with the defective button and use it in the bedroom sans one button. I've updated the remote with no problems.
I don't even think Logitech could lock out a remote if they wanted to.
Perhaps they've altered the firmware to make batteries last longer? I'm not sure if it could be changed to brighten the screen. Others here may know. I assume you tried different batteries or swapping batteries between the two.
Discussion Starter #4
Yes I have tried changing batteries. No change to the brighness.
As to the lock oujt, that was what I was told they were doing with the old control. I will try as an experiment reprogramming it to see what happens.
Discussion Starter #5
Neat.. So I now have two 550's; one with a defective channel + key (it's intermittent) and the other with a slightly dimmer LCD. Mot a bad deal!
1 - 5 of 5 Posts
