1 - 8 of 8 Posts
I am repairing this unit for a customer. When the unit came in, all 4 orange LED's were flashing one after the other. I replaced a bad cap in the P/S and it does the same thing. Does the DSR505 need to have a Shaw Direct satellite connected to stop the flashing LED's? Or do they normally stop flashing after being plugged in to power without the satellite hookup? Thanks.
I think the unit is trying to download the current firmware from satellite. It will keep in a non-functioning state until it completes its program to contact the mother ship. Of course that is if there is no other problem such as a hard drive failure.
The scrolling LEDs are just its boot indicator. It should complete and go to a channel/clock display or no LED, even without a satellite signal (in which case the satellite LED should light red).
My last used 505 does that okay.
Edit to add: if it does that scrolling for some time, press and hold the power button on the front for several seconds and let it do a soft reboot. It may go to a channel indicator then.
I might be mistaken, but isn't it so that Shaw Direct is no longer supporting 500 series receivers? I know they aren't supporting 530s. I guess if they're already active on an account they're grandfathered, but otherwise they can't be activated any longer. Like I said, could be wrong...
The issue is this one booting or not (with no satellite connection I reckon), not activation.
I presume it is already active on an account.
But even if it does boot, are there any channels it can still receive? I thought SC was just about to complete the MPEG4 conversion.
There are still many of the SD channels in MPEG2 CBC,CTV, GLobal, City and East and West HD Us Feeds are still MPEG2. I believe the US Networks go MPEG4 next spring. TH 5xx Series will work as an SD receiver until the final conversion finishes in 2019.
1 - 8 of 8 Posts
