This AV receiver (Panasonic SA-HE70) has been an excellent unit up until recently when the speaker relays wouldn't always connect, resulting in a combination of speakers not getting amp output. Yesterday was an example, as we had guests over and we wanted to watch the Blu-ray of Avatar. On power-up, there was only sub (self powered) and surrounds. With repeated popping of the speakers/headphone push button, (you could hear the relay clicking, and it was a little anemic at first), the front centre started working, then after some time of popping the speakers/headphone button, the front right came on, but the rears dropped out, but more button pushing brought all but the front left on. Eventually, after 8 minutes of toggling the speakers / headphone button, all speakers came on. The absence of any speaker was confirmed with the "Test" button on the remote that sends white noise to each speaker at a time, showing it on the main display. When it all works, it sounds fine.
Has anyone has a relay of that complexity replaced? Or is it better just getting a new entry level surround receiver? This one ran in the price range of $300, and has worked very well. Being in an apartment, blasting at theatre
levels isn't an option.
Everything else on it works 100%.
It routes audio only, no video is routed through it. We're using just the coaxial SP/dif and optical imputs only. Speakers are JBL 5.1 (powered sub).
Any advice greatly appreciated.
Cameron
Cameron
