Status
Not open for further replies.
1 - 3 of 3 Posts
So a couple of months ago my HP laptop died, leaving me to buy a new one. With help and advise from here I bought a Toshiba Satellite. Thanks!
Now I'm back with a new issue, should be fairly simple. The hard drive from my HP is still good and I bought an enclosure for it, however it had a partition on it from the very beginning for "HP Recovery". Anyways, I don't need the recovery partition anymore, and before I get tons of data saved on this hd I figured I'd ask how to remove that partition? I have created/deleted partitions on hard drives before I just can't remember how as I don't do it often enough.
So anyone have the steps required?
I really appreciate it.
Premium Member
If you are using an enclosure, and windows of course, you can use the disk management program to remove and format your drive. It's pretty straight forward.
1 - 3 of 3 Posts
Status
