After spending three days researching remotes, I'm no closer to understanding what I need to run my gear the way I need to.
My LCD is wall mounted with my receiver/amp/blueray etc in a built in wall shelf at the back of the room.....so I have a line of sight problem
I was originally thinking that a remote with IR blaster would do the job, but there is no room to place the blaster so that it would fire towards the components. Then I was thinking that an IR extenders with the little stick on pods??
But would a remote that just runs RF do the job? Also recommendations as to what remote would greatly help
I'm currently running
Sony 46" HX LCD
Bell satellite receiver
Yamaha 6063 receiver
Sanding c5900 BD
Pup
Sony 46" HX LCD
Sanding c5900 BD
Pup
