About a month ago I built an antenna using coat hangers and an aluminum foil reflector. It is in my attic and has performed pretty well. I am getting a number of channels from 45 and 50 miles away.
Here is the basic design I used. Added the reflector that isn't on this design.
http://cdn.makezine.com/make/television/04/DTV_Antenna_FINAL.pdf
I am now in the process of making a gray hoverman from pvc and steel wire. I am also planning to put this in the attic, replacing my original antenna. While I realize that not all antenna's are created equal, I am trying to make this as cheaply and easily as possible. So I was thinking I would use an aluminum foil reflector again. Would I get a *dramatic* performance boost from another reflector? Wire screen / Mesh? Rods? Again, if one will only get a 5% increase over the other, I would rather stick with the cheap foil. But if using rods would give me a 50% boost, I would probably think about it.
As a point of reference, my investment in this antenna is probably only about $10 so far and I would like to keep it really low. Also, I would like to keep construction very simple as I have been passing off instructions to friends and co-workers.
Thanks!
