1 - 2 of 2 Posts
I was looking to buy a used bell dish for HD. A have found 1 that comes with a Recoton DSV95. Is this the sw44 i need. I did some research on this particular switch and haven't found much info. If this is what I need the other question I have is it a good switch or should I find a better one. Would I lose signal quality with this specific switch.
That is NOT the switch you need. It is for a Dual LNBF and Off Air Antenna, not for 2 x Dual LNBF's.
Used Bell Dish's are plentyful and you should try to get the VideoPath SW44 as well, as that is the standard used by Bell.
You could also go the DPP route if it is all new to you.
1 - 2 of 2 Posts
