1 - 4 of 4 Posts
Hi All,
First post here, I'm new (Yes the username is from It's Always Sunny in Philadelphia).
My beef, is that my Shaw box has recorded the wrong program twice when I've tried to record ENTOURAGE on HBOHD 243. The first time, instead of recording a NEW episode, as I have set on the series recording, it recorded a rerun.
Recently, it recorded some other show in its place, even though when you hit INFO, it lists the new Entourage episode description and in the Recordings list, it shows Entourage. I then said screw it, I'll record the second heat 3 hours later. That recording was GOLFHD Donald Trump's World of Golf.
Anyone else having this issue, and maybe hopefully know the fix??
Thanks.
I had the same thing this week. It was probably a guide hickup.
Hung and Entourage each recorded for an hour when they're only ½ hour shows. I found Entourage was tacked onto the the 2nd half of the Hung recording and Durham County was the hour show labelled as Entourage.
Frustating but at least these shows are on a few times each week so you can reload and try again.
1 - 4 of 4 Posts
