1 - 10 of 10 Posts
I recently moved back to Canada after spending the past two years as a postdoctoral fellow at a university in Germany. While there, I accumulated several good German-language DVDs, but in my haste to move, I never thought to bring my German DVD player with me. Of course, these DVDs will not play on my equipment here. I have read that there are region-free DVD players, as well as ones that will convert data read from PAL DVDs in the player and output the necessary format for a NTSC TV, but I am a bit confused. Can one simply walk in to a store and buy such a player, or must you buy a region-specific player and modify it somehow? If such a player can be directly purchased, which is a good one to buy? Thank you.
Probably the easiest (not sure about cheapest) way for you right now is to get a Seiki BD660 BD player from Walmart, $88. It will play all regions/areas of BDs and DVDs, does the format conversion if necessary (many panel displays don't require it). I don't know of a DVD-only player that's conveniently available right now, when they are they're often in the $30 range.
The BD660 actually works quite well, as long as you're not using a projector->very large screen. It's not built particularly well. :) Thing is, no region-free DVD player now available at B&Ms in Canada will be well-built, they will always be secondary brands/quality at best. One brand exception is you could get a used Oppo DVD player. Or you could buy a new Oppo BD player and get a mod to allow it to play other region DVDs...starting at over $300 total (actually, to be worthwhile for DVD compared to the Seiki, you'd better spend for the higher model BDP-83 + mod). If you only have a few non-R1 DVDs, probably not worth spending a lot.
I guess the moral is if you want to buy new, you probably have to look at BD players. The Seiki is the only one easy to get, that's region-free straight out of the box, and just happens to probably be the cheapest.
Premium Member
... you could get a used Oppo DVD player.
+1 to a used OPPO DVD player (OPDV971H, DV-970HD, DV-980H, DV-981HD, DV-983H) in good condition.
You could also search VideoHelp.com for format-converting players, see which of those have region-free "hacks" available and then check to see if they're still being sold.
That player would also have no problem displaying a PAL disc on a NTSC TV, right?
There should be an option in the set-up menu that lets you select what video format you want the player to output (regardless of the input format).
As eljay said, there is a menu option to select the type of display standard you need. I have used the BD660 with PAL DVDs on an NTSC display, and also with a panel that takes NTSC/PAL directly. There is a thread in this subforum on the BD660, but I don't think you necessarily need to read it now. Not all Walmarts have the BD660, and they may not be shelved with other DVDPs/BDPs so may have to look around (not likely worth asking in-store :)). Somebody rumoured they were available for $50 now, somebody else said $99 at their location, but $88 still seems the norm. You should put your location JIC somebody knows your local availability. Edit: hmmm, 7 left locally a couple weeks ago, only 1 left today...
For DVDs, the Oppo 98x models are pretty good and well-built and not "too" old. Good luck getting one for less than the Seiki though: used Oppos seem to hold their value quite well, as they are some of the few straight-out-of-the-box region-free DVDPs that are also well-built. Should mention Yamaha too, I have one of them that's region-free "in reserve" and it's nicely built...but not a current model. New there's not much.
If you want a good BD/DVD that is region AND zone free, get the Oppo-83 from Singapore. Without any hardware hack (it's actually in the manual), it allows you to change region (for DVD) and zone (for BD).
NCIX has a Sherwood BDP-5004 region free Blu-ray player available. A friend of mine bought one a few weeks ago, when they were on sale, and she can now watch European discs.
If you decide to get the Seiki, you must use the following procedure to make the playher region free
Ensure no disc is in player
Power-up the player from 'standby' to 'on' with the remote
Once the green 'Seiki' wallpaper appears press the 'Setup'
button
Press these numbers sequentially: 8, 5, 2, 0
This brings up a 'Factory' menu where you can change the DVD
region code (use Region 0 for region free) and you can change
the Blu-Ray region too (there's no 'region free' option, so
you'll need to change it per disk)
The Sherwood is region free right out of the box and sold as such. The only thing I had to do was change the video output from Automatic HDMI to 720p (to match the TV). Otherwise the TV didn't recognize the signal when playing a PAL DVD. Another set that can already handle PAL, such as my Sharp Aquos, might not even need that change.
1 - 10 of 10 Posts
