hello everyone
i was wondering if anyone has run into this situation. i have 4 receivers on my system older oval dish, dual standard linear lnb, going into a 3 in 4 out switch. here is the problem, as long as any one of the receivers stays on channel 505, the other three work great on all channels. if i switch that receiver to another channel the other three receivers start acting up and i get red light on a lot of channels. put one receiver on channel and all the rest start working perfect again. tried swapping lnb, switch, coax, and resetting receivers. still same problem. two other friends are haqving identical problems. only difference on theirs is, they are running 2 dishes with dual lnb on each and using a zinwell 4 in 4 out switch. any ideas? we are really scratching our heads on this problem. thank you very much in advance for any response and also, thank you for allowing me to be part of this super informational forum.
