Just wondering if anyone has any idea what the issue maybe.
Just switched from bell express satellite over xmas and i notice sometimes the pvr will miss a show randomly for no reason (these are all set to first run and rerun).
These shows are typically shows i like such as the fifth estate, dateline, 48 hours, i have set it to first run and rerun, and to record once per day at any time for how frequent it should be recorded.
When i first got optik i noticed it was missing 48 hours and dateline eps occasionally at random, so i redid those timers, now all is fine. Then today i was looking up my upcoming schedule and noticed the fifth estate was not schedule to record friday (I had not noticed an issue with that one before). I double checked and it is on friday..... the timer is set to record first run and rerun at any time once per day....
I deleted the timer and set another one, and it picked it up just fine. I dont get what the problem could be? Does anyone know, its quite frustrating?
Is it possible on all of these i likely had it set up incorrectly from when i first switched to telus, i often went back in and changed things such as first run to first run and rerun and instead of at this time i set it to once per day at any time. Do you have to get the recording right the first time or it might get corrupted? I just dont get it but that is all i can guess?
Those recordings i set when i first got optik all needed to be redone because they would skip certain eps for no rhyme or reason at random as far as i can tell...
