I just discovered this site and it looks like the best solution so far to control the PS3 using IR controls....haven't tried one yet, and it's a bit pricy considering the exchange rate. They're currently out of stock but more are due in any day now!
Full IR Control of your PS3 -- All 51 keys and combination keys, POWER ON AND POWER OFF
Both built-in AND user programmable macros for power off / shutdown
Wireless connection to your PS3, works from up to 30 ft (10m)
Easy setup using the ps3toothfairy profile in your Harmony remote -- Fully supported by the Logitech Harmony software
Integrated control of your PS3 with automation systems such as Crestron and RTI
Discrete power control with the PowerTrack feature
Autosensing, wired IR port compatible with Xantech, Niles, RTI, Logitech Harmony RF Extender, and other IR distribution systems
User Configurable operation to support a variety of installation options, including multiple IR addresses
Multiple power options -- USB power cable, AC Adapter (yours or ours, 3.3-12VDC Regulated), or hardwire
Small, about the size of a deck of cards. The ps3toothfairy AND micro AC Adapter weigh just 7oz (200g)
Worldwide shipping
Worldwide shipping
